Big_Guys_baby
My 1946 Biz Coupe seems to have a charging problem. Still 6volt pos ground, all the wiring been replaced, many additional grounding wires added throughout.
Dash ammeter showed super erratic charging followed by discharge. Did the open voltage test (disconnected arm and field from regulator, connected with bolt... tested with multimeter to while engine running) and showed super low voltage at fast idle.
Took off the generator, removed casing and the general condition inside the generator is super dirty. Still lots of "meat" on brushes but one side totally erratically worn.
What is the best method of DIY cleaning and tune-up of this to see if I can get it charging? Should there by continuity between the Field terminal and the Ground terminal on the casing?
Surfaces on armature look quite corroded/dirty. How much play is allowed on the front pulley bearing?
Anyway to use a multimeter to bench test in my shop before I reinstall?
THANKS!
Jeff
THANKS!
Jeff
