Divers helmet distributor help
sln123
Hi all
Can anyone help with a problem with my 1937-40 divers helmet distributor . Hopefully attached a pic of the centrifugal advance plate which to me (and compared to an exploded pic on the net) seems excessively worn. Does anyone have a pic of a non worn one or know what size / shape the hole should be.
Many thanks, Steve
No its not worn,those yrs are made that way. The holes on a 32-36 are a slightly diff shape. Your ok. ken ct.
I agree with Ken, its not too worn.
These can be put on backward , make sure you try it with your hand before completly assembling it back together....
Thanks for the help guys. Looks like it must be something else causing issues with my motor.
Cheers, Steve
Cheers, Steve
Steve,
Discribe your problem. If you truly have an ignition problem Bubba is the one you want help from. If it is something else someone on here can provide advise.
