Hi, i'm new here...
I need some input on this distributor instal.
the housing fits the head, and pilot dowel is a good fit in it's hole.
The shaft is the same length and diameter as the one that came out ( single shaft )
I have measured all the hole depths, shaft sizes housing sizes, and even reached carefully down into the block and cleaned the drive tang near the cam.
The distrbtor goes in the tang clicks in but the distributor stops going down when it is still .050" too high In other words it wont go all the way down.
Any thoughts?
Thanks
G
Any thoughts?
Thanks
G
