Distributor wire question
vintrex
I was going to swap out Dist. wires with a new unused uncut set of wires but wondered if the 6v Vs 12v would be an issue? All advice is appreiated...
I have been around the block a few times about this. Unless it is a factory correct restoration, I always go with Packard 440 solid core wire and Rajah spark plug terminals. I get them from the Brillman Company and have never regretted it. The positive "click" you hear when putting on a Rajah terminal on a spark plug is very satisfying.
Electronic ignitions excluded. you want solid core... outside spiral bound resistor wire for electronic ignition.
solid core & rajah ends from Brillman.
