steve fritz
I am looking for advise on a 302 Ford engine question. I have a 1982 Ford 302 stock engine that I am installing in a 51 Ford. I didn't want to keep all the smog controls, air conditioner , power steering and the serpentine belt system on the front of this 302. So I found the front v-belt system parts from a 70 Mustang 302 and swapped it onto the 82 model 302. That worked just fine. So now I also swapped out the 1982 ignition distributor and am running the older style basic distributor with points and coil. My question is with the spark plugs. Now the 82 version heads take the smaller pencil size spark plugs and call for a 45 thousands gap. But my thinking is , because I switched to the older distributor and coil, i SHOULD SET THESE SPARK PLUG GAPS MUCH TIGHTER, LIKE THE 34 THOUSANDS IT CALLS FOR WITH THE OLDER STYLE DISRIBUTOR AND COIL. DOES THAT SOUND CORRECT ??????
Any thoughts on this swap would be appreciated, and is there anything else I should do? I am not into super high performance, just want a nice cruiser engine. I was considering switching out the points to the Pertronics pointless system, but that can wait.
Steve
Steve
