Distributor Upper Contact Plate
mach0415
I recently bought what appears to be a very original 1928 Canadian Tudor. As I have been going over things, I began to check ignition component clearances and noticed the points did not line up correctly. I purchased a new set and when I went to install them, I noted the new set do not align correctly, but there is also no adjustable block in order to align them. I attached pictures, because based upon other pictures, I am now thinking the upper contact plate is not original. It appears to have some sort of copper or bronze finish. The pencil is also pointing to a broken bake-o-lite insulator (it flaked apart as I was installing the points terminal stud:eek:) and now the plate will need replacing anyway. Any thoughts on whether or not this is an old aftermarket replacement plate? :confused:
Thanks in advance for any info...
That's an original 28 plate .In fact my Briggs 29 Fordor has one .
The stamped style came out later
You might be able to swap the bac-o-lite from the later type
Thanks for the response. I may just run a stamped version and seek to restore this one at a later time. It would appear that points have grown about 1/8 inch over the years too, so the contacts do not meet well. Perhaps in that time I may find some that do.
I do believe the very early plates had different points so that might be your problem.
I have never seen any other than in a photo but the early points would just slip in with out unscrewing the nut on the bottom of the plate. They changed it because people could steal them or the car, can't remember exactly. So you have to lose the timing to change the points after they modified the design. I have a couple of the 28 design, the layout of where things are is a little different but it works fine, I think I put a new fiber plate on one but made it new so it would line up. Could be Ford contracted with several vendors to make the things.
I bought aftermarket points from Napa they don't line up,I compared arm length to Ford script points,the Eschelin arm is longer.
