Richard Lorenz
The diagrams in both the Snyders and Brattons catalogs show that this washer should be located at the bottom of the distributor just above the sleeve. The distributor that I am restoring shows wear at the top where the upper shaft is supported. It seems to me that because of gravity, it would be smart to locate the 0.015-inch thick metal thrust washer (Snyder's A-12180) at the top instead of at the bottom. With my parts, there is not enough space to have thrust washers at both the top and bottom.
Considering both gravity and the wear at the top of my distributor, I am going to put the steel thrust washer at the top. This will locate the cam at the correct height. Any comments?
