nkcarizona
I have a problem with the modern points with wireless pigtail that I have installed in my 29 Fordor. The arm on the points works itself up the post bringing the connector that contacts the wireless lower plate up with it. After a short drive the arm works up far enough that the connector shorts out on the upper plate, and I'm dead in the water.
Has anyone else had this problem? I know I could go to the setup with a wire pigtail rather than the wireless pigtail, but would like to make this work if I can.
