BILLF/TRF
My original purpose in removing the engine from my '31 Tudor was to repaint the engine. But as suggested on this forum, I thought I should check my mains and rod bearing clearances while the engine is out but need to get at the nut behind the oil pump distributor dirve gear spring. I have a two piece distributor shaft. The upper shaft came out with the distributor but the lower shaft did not and is blocking that nut. Is there something holding it in or is it just stuck in the drive gear sleeve? How do you suggest getting it out and also how much "slop" should I have in the distributor shaft? Thanks.
