psimet
Long story but I got into a situation where I cracked my distributor casting. I ordered a replacement (not going to say where as I haven't even tried to call them and won't if I find a quick solution) but it came with the shaft and corresponding parts assembled.
The roll pin they used on the lower shaft "collar" isn't pressed all the way in and the shaft is already binding slightly in a couple of spots when rotating. If I put the pin in all the way the shaft locks up. I pulled it and took the thrust washer they have on the bottom off and of course now there's a lot of clearance in the shaft. The washer in there is roughly 0.015"
I have a lathe, have been a machinist in my misspent youth. I was looking for quick solutions as I was wanting to get the distributor in the car this weekend. Was thinking I would put the collar in the lathe and take a couple thou off the end but was looking for what my target should be for overall shaft end play. 1-3 thou? (0.001-0.003)? or like 0.005?
Thoughts?
Thoughts?
