I have a 312 56 in a tbird. The distributor has a dual vac advance. When I attach the vac lines to the distributor (AT IDLE) the vac advance immediately advances the timing just a little. It causes the engine to run a little rough at idle. Once the engine is above 800 rpms it seems to run fine. My question is, should the timing be advancing at all during idle? And if Not does this mean that the return springs need to be replaced or adjusted. If they need adjustment, can some one tell me how to do it?
