Distributor position
msstring
How do I know how to line up the distributor in my 8BA? I have the pin lined up with the dimple on the front pulley. Should the rotor point to #1 position on the cap?
Sent from my SM-G973U using Tapatalk
Yes. You will be either correct or 180 degrees out.
TDC should be at compression stroke for No1.
Phil NZ
