distributor oiler how much oil?
Standing Elk
So when you fellas fill the oilier on the outside of your distributor, typically how much does it take to fill it. Seems like mine only takes a couple - three drops.
Mind you that if you fill it it will drain into the bushing within a few minutes. It will depend on what you use to oil it - it only takes a few drops from an original oil can.
Fill it until it won't take any more & you're done! The oil will find it's way where it needs to go. Check it every month or so, depending on how much you drive and don't let it go dry.
Happy motoring,
Mike G.
Fill it full is in the owners instruction book, I lay a rag under the oiler, give a couple of squirts with oil can, a few miles later there's slight dampness of oil at top bushing so I know it is oiling it
