Robbie1
Hey guys! I'm trying to sort out my distributor. It was running good when disassembled, but why not make it right, right? I'm amazed on how vague the Mechanics Handbook is. There is about 1/4 inch play on the shaft (up and down) and a little wiggle on the lower side to side. Do I need to drill out the pin holding the upper shaft to the lower? Does it punch out? Most videos I see don't even show that these shafts are pinned together.I have a new upped shaft that's drilled for oil. I'm waiting on new bushings which will be another step. I assume now I will need the lower shaft ( this one is pitted ).
Thanks for your help!
