Hivolt5.0
I have a question concerning the distributor gear for a 302. I'm putting a 302/AOD from an '89 Grand Marquis into a '48 F4. The engine was obviously originally fuel injected but I plan on running a carb. I assume I'll also need to change the ignition system since the fuel injected motor would have utilized a TFI module on the distributor. I would think converting it to a duraspark ignition would be appropriate. However, looking at the lifters it is a roller cam and from my Fox body Mustang days, I seem to remember that a cast iron distributor gear can NOT be used on a roller cam. Is this true?
