bluesman31
I am replacing the entire distributor assembly top to bottom (as much as is available repro). The gear at the very bottom of the distributor shaft (located inside the valve cover) that drives the distributor needs to be removed from the bushing assembly that holds it and that bushing is reused.
There is a .125 solid steel pin that holds the gear assembly together, and I ground off the peened end and removed it with a punch.
Can anyone tell me if they have done this before and if they replaced this pin with another solid pin or did they use a roll pin? I bought a steel pin at the hardware store and the dang thing is so hard I cannot peen it. It is making a mess of my punches and anvil!
