The manifold should not have anything to do with the distributor. The advance curve is changed by messing with the springs inside the distributor.
http://www.bubbasignition.com/49-53.html
Might explain a little more about what you are attempting to do. If it involves much modification to the engine you would be a lot better off replacing the load-a-matic distributor with a distributor that does have both centrifugal and vacuum advance, or at least centrifugal advance. You can modify Chevy distributors to work or use an aftermarket distributors such as a Mallory.
http://www.bubbasignition.com/loadamatic-replacements.html
The Bubba links are for reference only as he is currently not accepting orders. There are other sources/individuals here on the Barn that can help you with a replacement distributor if that is something you are wanting to do.
