emf
We have an interesting problem on a friend's A. He went to start it after sitting for little over 8 months and the distributor shaft broke at the bottom slot that mates with the drive shaft from the cam. We pulled the distributor and there was a mass of rust preventing the distributor shaft from spinning. We have a long shaft from another distributor but there is another issue. When we inserted the replacement shaft into the hole in the head, it engages the drive shaft but it can spin freely. If we turn the engine over using the hand crank, I can hold the distributor shaft and can keep it from spinning. It seems the gear that mates with the cam shaft is turning freely in position. So here is the question, when I read Les Andrew's book, it looks like that drive assembly can be removed from the engine through the side cover without dropping the oil pan. Is this correct? Then, can I just inspect it and replace it the same way (once the fault is corrected, of course)?? I never have had one apart, so I'm looking for help on this one. Thanks.
Frank
Frank
