Can the Distibutor drive gear be replaced without pulling the head? I have to much play in turning rotor, what about the oversize gears anyway to tell if oversize needed? Thanks
How much is too much?
Have much lash is my same question ? The lash can also be in the drive shafts not just the drive gear.
Thanks for all the posts. The reason I suspected to much lash was engine in 30 CCPU said to be rebuilt 7 years ago less than 10K use. I have had 3 years, truck runs 55 mph very easy no overheating, but will not idle slowly. Engine bored 125, lightened flywheel, 5.5 snyder head, original type points. will not run good when timed Ford way, Red book way also used the new type NuRex wrench. If the rotor is set at a contact point in cap you have 2 widths of the rotor tip free play!
Why is it not a good choice ?? I have never had any problem with them, & as you said, its just one less shaft to wear out..originally the shaft was a 2 piece so check both, the female end also wears out.
A single shaft is not as good a choice. The original 2 shaft design was not as ridgid.
I think the rotor turns smoother with the correct, 2 piece shaft.
Bob
Thanks for all the input. My shaft makes Tom,s look good it looks like a knife blade! have ordered a new one.
