James Rogers
You have it correct. I, like Tom, have never found a distributor that would take both washers.no one has commented on this issue yet, any advice?
Problem #2 reared its head when installing the new shaft in the distributor. The shaft will not allow me to put the two thrust washers that Snyders sent me between the sleve and the base of the distributor. I installed a metal washer and left out the fiber one that was sent. Hopefully this won't be a problem???
