Distributor Disassemble
- VACUUM ADVANCE CANISTER STYLES - 57-59
- 1957/1959 SGL BREAKER PLATE - B7A 12370-A -
530900
- 1959/ DUAL BREAKER PLATE STYLE B9AF 12370-A -
530901
There were other changes (advance plates) 1960/ so you will need the DIST ID NO to ascertain which canister will be correct for the application.
EDIT -
- Application Date(s) Corrected -
:mad: Give Me Forty Acres And I'll Turn This Rig Around ... :rolleyes:​
How does the vacuum advance work if that plate won't move it's pined to ?
It doesn't. Whether the one piece or two pieced breaker plate assy is frozen or the vacuum advance canister diaphram is bad, there will be no vacuum advance.
Usually there will be a tip-in hesitation as with a bad/mis-adjusted carb accelerator pump.
Maybe read and consider a PERTONIX II setup-
https://pertronixbrands.com/collections/ignition
https://www.helmarparts.ca/v/vspfiles/pdf/catalog/Pertronix Products.pdf
In today's world if I had a classic, I would be afraid to take it out.
:eek:
- BEAUTIFUL EYE CANDY -
530877
With a GEL FILLED COIL you can keep the same coil mounting.
Did the car come through with a 292 2V?
Is that an OFFY 3X2 INTAKE?
It's begging for a set of BIRD ROCKER COVERS ... :D
Yes Yes I have a device currently that tracks the vehicle location.
