distributor cap
cb
Does anybody know if somebody makes a dist. cap clamp on style with male connections hei style instead of the push in female style that would fit an OEM 65 small block ford distributor.
later ford caps will work. they come in 2 sections. lower section (adapter)attaches to the dist. just like a stock cap and the top with male connectors attach to the center section. will fit all fords '57- 80's probably. get matching rotor also. I usually bought them for mid 70's pick-up. because that's what I found in the junk yard. Used this set up on our 302 for yrs. The cap is somewhat larger than stock but I heard it was to spread the plug wires or cap contacts further apart to stop cross fire. I've heard people look at it and say he's running a HEI dist!! I would run this set-up on our 292 Y-block but I don't think it would clear the firewall
