JimG1127
I want to set the point gap and set the timing on my A that i bought a month ago. Cannot get the Distributor cam screw loose. Probably hasn't been adjusted in years. I sprayed it with WD40. Put the cam wrench on it and tried to loosen the screw. Nothing. I'll try it again tomorrow. Any tips? If I can't get it loose do I need to take the distributor apart?
Thanks.
Thanks.
