There are little sparks that jump from the rotor to the contacts inside the housing. That may create enough heat to melt solder or even silver solder.
Update: The spark is not enough to melt solder, depending on where you put it, see posts #10 and #11.
First, make sure that the distributor body fits snug on the distributor. If it does not then it can move and change the gap at the different contacts. Besides buying a new body, you could try filing down the closer contacts and then bending the rotor as crosscut talked about, above.
I found that my car runs better with a small gap between the contacts and the rotor. I think the specification is 0.025 inch, but I run about half that amount. The trick is to have the minimum gap without crashing the rotor with the contacts.
