Distributor b cam .best vendor
Josh,
I think the reason for no replys after a couple days is we dont know what you are asking.??
Do you need a distributor ?
Or are you looking for a Model B camshaft......???
Wanting quality or something that will run good..
A little confused??
b
Model B Distributor Cam, Best Source?
Model A and B dist. cams interchange and most think the profile for the B is improved. Replacements that use the B profile may not even be listed as such may not even mention it. Remember that the oil passage on the majority of B distributors is not drilled through and oiling is a waste of time unless they are fixed. Good Luck: Fred A
