satelite
I'm working on a friends 31 model A with a new Miller overhead valve head. Someone told me there is a distributer expert on this site that has the answers. The engine has been totally rebuilt including inserted bearings. The problem is that the car sputters and back fires during acceleration under load. Ok when standing still except under sudden acceleration from an idle. I have replaced the coil and condenser, points are OK. The distributer is a single point Mallory. The system is 12 Volt and I have a New Rex timing kit so I can use a timing light. Initially I set the timing at 3 degrees at 600 RPM which yielded 25 degrees at 2400 RPM. I tried with 10 degrees at 600 RPM which yielded 25 degrees at 2000 RPM.
Still no power and it backfires during acceleration under load. Compression test shows 115 PSI on all cylinders.
Any suggestions on what to do ?
Don in SC
Don in SC
