harry goebel
I have already instaled the Disk Brake kit on the front of my 53 and trying to make up my mind if I should stick with the original Master or go to a dual master from a 67- 70 Mustang that is set up for front disk brakes and rear drums. What did you do and did you install a residual valve or a adjustable proportioning valve in the line going back to the rear drums? used the Engineered Components kit. Appreciate your reply.
