Hello
I have to remove the rear end on my 1937 Ford (clutch issue) and need a little guidance when it comes to removing the shock absorbers.
I suppose the easiest way is to disconnect the absorber link that connect the shock absorber to the axel and not loosen the whole absorber from the frame.
I have raised the car on stands and removed the wheels. I have also loosend the two nuts that holds the shock link. But the shock link doesnt come off easily. Do I have to use a puller or something? Was it wrong to raise the car from the ground? I have not used any force yet, I thought it was best to ask for help first. Are there any spring with tension in the shock absorber that I should be aware of?
Regards
Knut Haakon Naess
Regards
Knut Haakon Naess
