Thanks for all of the tips. EC has the parts I needed; will see if all goes well when they arrive and I get them installed. Found out that the Wildwood calipers on the front are dual piston @ 1.75 in., so was told by Mark at EC that I would need a 1&1/16 bore of a dual master cylinder with a 2 psi valve for the front and a proportioning valve. They have an adapter plate to convert from my 3 bolt apparatus to a 2 bolt for the master cylinder. No power booster at this time since I am running the original flatty engine and doubt that it would have enough vacuum to support the booster.
