jrapose
I have had disk brakes on my roadster for years....with no vacuum assist..and I would not want one...it stops easy and quickly...works fine...there are some tricks though...
The kits most places sell will not work using wire wheels...there is too much setback on our rims to allow for the caliper clearance.... it won't work using our wheels...
The rotor hats I used were Suzuki Samari ....they are 5 on 5 1/2 pattern and have a large setback... the calipers I used were Willwood brand but Volkswagen would also work...
You will want to use a AMC master cylinder as the outlets are on the oposiite side than a Chevrolet dual master....you will be mounting the master cylinder backwards so you want the outlets pointing toward the frame... you will pull the tube seat out of the front part of the master cylinder as you don't want residual pressure in that front line...or you will drag your disks..
By using deep rotor hats you will position the rotor surface in line with your kingpins so it will not cause any kind of pull in a panic stop...plus you will not need to space your wheels out...I think that kinda look mickey mouse when I see a car where they have done that...
I use 40 Ford rear drums so I use a late model Ford proportioning valve that I make adjustable...(easy to do).. but you can buy adjustable valves if you want.
The only thing I would like to do now it to change the backing plates on my drums to make them servo brakes ....as they are now they have 2 anchor positions ....and do not self energize.
Joel
Retired College Shop Teacher
Joel
