cuzncletus
I have a 46 59AB that was rebuilt .040 over back in the 70's and not run much since. When I did run it, it ran fine; quiet, smooth, no smoke. I pulled the heads to inspect it and found little to no ridge in the bores and no cracks around the exhaust valves. It also was rebuilt with Johnson adjustable style lifters and I thought a mild cam. However, when I put a dial indicator on several of the valves the total lift came out to .290 +/- .02. From what I've researched this is less than stock if I'm reading the lift right.
If the cam is worn it's worn pretty uniformly, something I've never seen before in worn out cams and brother I've had my share. That it ran quiet would seem to indicate that the valves aren't too loose. My dial indicator is a cheap Harbor Freight but seems right when I've miked pieces to compare it with. Am I looking at this correctly?
