JSeery
Might try a lower vacuum source or restrictor to lower the air movement. You would also benefit from installing thermostats. You could install them in the upper hoses near the radiator. With typical modern thermostats you would need two hose clamps on each to hold it in place. Another approach would be the inside the hose thermostats similar to the originals.
