After approximately 12k miles, 2 1/2 years since assembly, my engine started making rapping sounds, similar to valve train noise. Checking the valve adjustment,springs,et,not finding anything.
Went to start engine the other day,turned half a revolution and seized.
We pulled the engine. Upon disassembly,found the dipper tray had come loose, and was jammed between the block and crank.
Considering how the tray is attached into the pan, can’t discern how this could happen.
Your thoughts.
Thx
Ken
Your thoughts.
Thx
Ken
