donald1950
i am having difficulty installing a ford-0-matic on a motor. removed tired 1953 EAB with ford-0-matic from car. installed flex plate and attached converter to flex plate on new 1953 EAB motor.
used dowels to line up transmission as per service manual and transmission stops with block and bellhousing about an inch apart and goes no further. have kept front pump tangs 90 degrees different from converter output shaft but trans wont go in.
is it better to install converter on transmission so as to line things up and then install trans with converter to block and flex plate? spent 6 hours so far trying to get trans attached to block. i have all spark plugs out so motor will turn hoping to line converter with input shafts, but no go.
anyone done this before, installing a ford-0-matic on a motor? any advice will be gratefully accepted...
if i have to i will haul both (motor & trans) to a transmission shop and have someone younger, stronger & professional do it, but this should be simple to do. the service manual makes it sound simple. i just do not know what i am missing..
thank you in advance for any and all ideas.....
