ModelA29
I just tried it on the left side of the banjo (looking toward the front). When that turned messy, I installed the vent of a modern on the left axle tube.
A lot of people install O/D and don't realize this. Maybe their axle seals leak enough to not have an issue. Mine started leaking soon after installation of my Mitchell.
Could you just add a vent where the plug is to grease the rear shaft connector on the Mitchell? You wouldn't need to drill/tap anything then.
