Zimmco
I came up with a simple tool to rotate the ring gear/differential when setting preload. It's easy to make, very light, and won't hurt the axle seal during all the assembly/disassembly it takes to do this.
Take a piece of approx. 11/16" conduit long enough to reach well past the end of the axle bell and allow an extra 6" or so. Flatten one end to form a loop around a second piece of conduit as long as the differential carrier is wide. Drill and bolt this, allowing some offset so it all centers in the carrier. Wrap tape around the cross piece on the ends so it fits snugly in the carrier. (Don't make the cross piece too long or it'll hit the pinion snout when rotating the assembly). See the photos below to make sense of all this.
I clamped a piece of all-thread to the end sticking out of the axle bell and measured preload with a ruler and a weight. Center the all-thread so it's weight doesn't affect your measurement. You could drill a 1/4" inch hole for the all-thread to pass through conduit rather than clamping it.
