TobbyT
What’s the difference between the F-2 and F-3 brake pads and cylinders?
I’ve got my old 1950 F-3 running very good. I’ve taken her out and run her through the gears. Everything seems to work just find except for the brakes. It’s a good thing I live in good ole flat Mississippi.Down shifting this truck is a challenge !!
I pulled the front wheel and drum on passenger side and found that the brake pads have separated from the metal shoes. They were just floating round in the drum. I went to the driver’s side to check it out. The brake cylinder had blown and brake fluid had coated the pads. Looks like I have some work to do.
