vonpahrkur
wondering if someone could tell me what the difference between a 1936 frame and a 1939 frame is, if anything. thanks.
also are the body mount holes the same?
And, depending on whether you have a LATE, or an EARLY '36 chassis, the rear frame horns differ between late and early, as seen in this crude drawing. DD
Thanks, didn't know this. also wondering about the two mounts on the back part of the frame on the sides, one is a rectangular box before the pickup and the other is a pad-like box that is narrow at one end then wider-are these the same from 35-39 and through 40? Also do pickups have these same mounts on their frames?
I won't stick my neck out there as far as those ancillary mounts are concerned and say that they are the SAME, 'cuz I ain't sure. But, the pick-up truck frames, although the same layout as car (per year model), DO NOT have those additional mounts. DD
Might be a difference in the radiator mounts?
okay, that's good to know about the pickup frame not having those mounts. Anyone else know about those mounts on the sides of the frame where the kickup begins and if they are the same on a 36-39 passenger car frame and possibly a 40 passenger car frame?
Thanks! V8Coopman, that makes it completely clear.
Radiator mounts on the cross member and has to be changed.
