H. L. Chauvin
Mr. Endy,
Your entire wonderful article on differential re-build is centered around sound mechanical engineering professional practice which is still used in modern times for accurately measuring & setting differential preloads & backlashes for modern vehicle differentials, as opposed to just "guessing" & "feeling" such intricate measurements of movement & "guessing" & "feeling" such resistance which can be measured accurately with a torque wrench in inch-pounds of torque.
In the not too distant past, because of mechanics guessing at & feeling these critical differential measurements, I remember quite a few Model A's traveling down the highway with the differential sounding like an amplified corn grinder.
In my humble opinion, the most time consuming part of differential rebuild is the removal & disassembly of the differential & mechanical brake system; cleaning of old caked 600W lubricant; preparing for painting, priming & painting; removing & re-installing internal parts; and re-assembly, & reinstalling the differential & brake system.
Then, the least time consuming part, but the very "most important" part of differential rebuild is the correct adjustment of backlash & the correct adjustment of preload.
Model A differential banjos were never designed to easily provide these adjustments & measurements; however, it cannot be overemphasized for one to follow "your" unique written recommendations on how to correctly & accurately provide these adjustments for a Model A differential.
There is no doubt that the valuable time given in your preparing these articles & other articles, is very much appreciated by "all" who rebuilt differentials & those who have gained knowledge from reading your articles.
On another lighter note, we know that you will continue to write very informative Model A articles in knowing that you will probably never be awarded the Nobel Peace Prize for your important works; but after seeing who they dished one out to recently, heck, I would never want one of these prizes either.
