gavin m
Hey Lars
As Mart mentioned I have had the same issue with my truck since I bought it. You are doing well at 700km I could drain around 1 litre of fluid from the trans to put back in the rear end after about 100km!
It came fitted with a Tardel baffle that obviously didn't work for me so my next idea was this...
http://www.jalopyjournal.com/forum/threads/torque-tube-oil-seal-tech.596142/#post-6625286
This didn't work either.
Now I have fitted one of these manual marine sump pumps under the cab floor just in front of the seat.
It is mounted on a simple bracket, the trans filler plug is drilled and a pipe fitting has been silver soldered in with the same done to one of the top rear axle bolts.
So far it seems to be working well.
