I have a great running and idling 30 Cabriolet that wants to die at stop signs. If I set the idol up to much it won't die. Does anyone have suggestions? I even thought about the float level. Changing the timing doesn't seem to help. Jerry
I had this problem. It ended up being a rebuilt Zenith with a top and bottom that really did not match up well. I had to cut a special gasket so fuel would not weep forward when stopping. It runs great now but took a lot of time to get setup.
These slides should help you solve the stalling problem. Be mindful that the 5/8" float setting is the starting point for an iterative process to find the sweet spot for your Model "A". It has been my experience that the float setting in various Model "A's" differs slightly.
Yes, ...and I would like to add another place often overlooked on vehicles with vacuum wipers. Many times we find vacuum leaks up at the wiper, -either with a hose entering the wiper motor that has deteriorated, or sometimes it is the on/off sliding switch that has a slight leak. These are very tough to diagnose with the engine running because of the noise.
