The primary function of these protectants is to provide a coating to help prevent corrosion and block moisture. When using them be sure you understand which application is appropriate for each. A non-insolating protectant should only be used on single path connections, such as battery terminals, grounds, connections between two connectors, etc. In multiple path connections or where an insulating property is required only a insulating protectant should be used! Examples would be any multi-pin connector, light bulb socket, spark plug boot, etc. If it is not clear to you what is going on between insolating and non-insolating protectants stick with the insolating! An insolating protectant will work in any application as long as there is good metal to metal contact, however using a non-insolating protectant in the wrong application will cause issues. Examples would be a light socket where it would short a two filament bulb terminals or short the terminals to ground. Likewise on a spark plug boot it would short the high voltage spark to ground through the boot. So be sure you understand what is going on if you want to venture into these areas!
