I think the Auburn has the same six bolt spacing, 3 sets of 2 bolts closely spaced, as a Long pp, making it easily interchangeable on a Ford flywheel. The diaphragm will have six bolts , equally spaced maybe about 5 1/2" apart which I think is similar to the Merc flywheel for the Borg & Beck pp.
Either you will need to have the flywheel redrilled or change to a Merc flywheel. I do know when you switch from a B & B 3 finger pressure plate to a diaphragm pp on a GM engine it requires a longer throwout bearing as the diaphragm pp is not as tall.
The spring in a diaphragm pp is called a Belleville washer. Some pp's have so-called "bent finger" Belleville's to keep the clutch pedal from staying on the floor at 6500-7500 RPM, but a flathead will be fine with the flat finger type.
