Diamond Block Model B / C Crank / All the good stuff!
jim galli
tonopah
nevada
Price
2500
Diamond block Model C engine, or, have it your way if it makes you happier, a Diamong block Model B engine with cast counter balanced crank. Very much to list.
This engine is about 80% done. Block is washed, magna-fluxed, align bored, decked, sleeved to standard, race ready!
Chevy valves are fitted and ready. NOS American adjustable lifters. Stock Model B cam measured and in tolerance. Valve train is done.
Head is one of the "cheater" 7:1 compression ones that looks like a stock A on top. It will likely have to be fly cut for clearance of your pistons.
Crank is drilled for oil pressure. Rods are NOS Model B and have not had the dippers closed or removed. Up to you. Pistons and pins and fitment will be up to the new owner, as well as engine bearing choice. Like babbitt? You can do it. Like inserts, go for it!
Oil Pan is a B pan modified for Model A use. It's all pretty and ready to go.
Flywheel is lightened, clutch is V8. Front timing cover is correct Model B unit. Side cover is also correct for the engine.
What did I forget? Questions? Oh yeah, the price. I have $2500 in this. I will deliver to either Reno or Los Angeles for that amount. Or, come on over to Tonopah Nevada for a get away.
So what is this stuff worth. Sheesh for 45 years I would have killed to have these parts, and now, they aren't worth anything?
Allergic to telephones. email is jim.galli@frontier.com
Cam is stock Model B grind.
Editing original post because forum decorum says we're not supposed to chatter inside the ad. I can only ad messages once every 3 days.
Jim, you won't find many buyers willing to drive to Tonopah without talking to you first. Most of the guys I know get a rash from computers. Buyers want to know if you'll separate parts. Or if you'll accept their offer. Of they want details the pics don't show. I'm just saying . . . .
