braol
Interesting thing: I checked any and all play in my steering per the manual and things are mostly good to go. Here's what happens though: I still have a bit of play in the wheel but it's not at any of the tie-rod or pitman arm connections. (I replaced all my tierod end springs, etc...) When my son starts to turn the wheel the pitman arm slides laterally. In other words, the pitman arm shaft slides about maybe 1/8 to 3/16 of an inch before the pitman arm itself starts to pivot. If you were looking at it, the pitman arm shaft starts to move either out towards you or away from you before the the shaft itself starts to pivot the pitman arm. I am thinking that maybe part #30 (sector shaft bushing??) in the Brattons steering box diagram https://www.brattons.com/assemblies/two-tooth-steering-assembly.html is worn on the end...allowing the shaft to slide in and out as pressure is put on it from the worm gear inside the box.
Ideas? Is that bushing a pain to change out. Would it require a press or is it a slip fit?
