Clem Clement
some said to mix two chemical to soak of heavy rust on ****** gears/case. I have forgotten what to use.
I use powder citric acid and water. Easy to use and easy to get on Ebay. Mixing amounts are easy to find on line.
Thanks. I'm remembering Acetone and ATF?
Remember any acid you use will also remove good metal as well. That is the advantage of a non-acid rust remover.
does anyone still use NAVAL Jelly?
