Yes you can batch delete. The number at the top shows how many in the batch. Check that box and all mesg will be checked in that batch. Go to the bottom and click the box, change to delete, and hit go. All checked will be deleted. If you want to save one in that batch, uncheck each one to save before you go to delete. Practice on a couple that you don’t want to save, just to be sure you have the process correct…….. Mark
