Delco distributor cam lube
1930marie
Anybody know where a tube of this may be purchased? Thanks - Michael!
AC Delco U1901 Distributor Cam Lubricant Lube GM
Standard Ignition makes some that is almost the same. I have a tube of the GM stuff
I bought at my first mechanics job. That was in 1966. My boss at the time gave me a hard
time for buying such a large tube. He said it would last me the rest of my life with electronic ignition on the horizon. He was right. I still have that tube and it has 3/4 of a tube left in it. If you can't find any, I'll send you a squirt of it......
I have the standard ignition lube that Dodge mentioned. It is readily available at my shops jobber. One small tube will last forever. haah..
The model A suppliers sell dist cam lube also...
Brattons part # 17490
Cam lube is high temp, also, & "stays" put. Some points had a little felt pad by the rubbing block. I used to "massage" a little cam lube into it, to lube the lobe longer. (Tip# 17)
Bill W.
Bill W.
I remember those points with the pads... They were usually the higher end ones
We can get cam lube here at the parts stores, my have to wait for it, but, they can get it.
I too remember points with the felt strip. What do I know, I squirt them with oil. But, points didn't move [ wear] like they seem to today.
Look on the counter of your favorite parts store, Advanced Auto in this case. A little disposable tube is about a buck.
Like Dodge above, I bought mine when I was in my late teens. My dad worked for a automotive parts jobber and thats what he brought home. Got a big tube and still have lots left. Will last a couple life times.
I asked at Carquest the other day, and the counter guy ended up going in the back and robbing the lube capsule from a set of points. Nice for me, but I bet whoever buys those points will be unhappy!
I find that many points now a days don't even come with that pill capsule... Can't remember the last time it did atleast with the standard brand
He could have at least coated the rubbing block with half the grease before he gave it to you. :D
I'm still on the same small tube I bought in the early 70's. :)
