How do you remove the deck lid handle base casting from the trunk lid of a 47 Ford. I've removed the large nut and the small nut at the top. It won't budge. Thanks Harvs
If you have removed the large nut around the handle mechanism and the small nut above that you've got them all. Lightly tap on the bolt of the small nut and you'll break it loose.
