Steve Plucker
This concerns the placement of the Deck Door where the upper deck door hinge brackets are on the INSIDE of the quarter panel. I believe that set up is on cars WITHOUT the Quarter Panel "T" Molding.
OK...That being the case, just what prevents the Deck Door in moving to the right and/or to the left if there is no guide to do so when the Deck Door is assembled to the body in the two upper corners.
I can see that there would be no movement with those cars with the Quarter Panel "T" molding as the bracket is on the outside with the raised area for the guide...but those which are inside? Hmmmmm.
Thanks.
Pluck
Thanks.
Pluck
